Old 21st March 2010, 10:14 AM
Enoch Enoch is offline
Default Brake master cylinder
Hi again peeps. My sierra had ABS so I need to get a non ABS master cylinder. All the ones I have seen so far don't appear to have the push rod with them, yet reading the book all the evidence seems to suggest that one is required. Can anybody throw any light on this? I think in the original car a pushrod went to the servo then the servo had something that pushed in the pistons in the cylinder Should I be looking at a different master cylinder?
Your thoughts would be appreciated, as always.
Enoch
Old 21st March 2010, 11:19 AM
Make or buy the pedals and there is a hole in the brake pedal for a push rod.
The original servo had the rod fixed inside it so you will need to make one
Old 21st March 2010, 12:33 PM
Buy a clevis and pin from somewhere like rally designs or CBS, then cut the head off a bolt to make your own - mine took about 2 mins including filing it nice to make.
Adrian
Old 21st March 2010, 01:19 PM
Thanks guys, I guess it will become a bit clearer when I get my master cylinder.
Enoch.
