Old 13th April 2010, 07:10 PM
gingea1pom's Avatar
Default Grub screw hole size for threading!
Here we go then.
I am planning to drill the holes for the grub screws in my Sierra uprights.
I vaguely remember from a fitter machinist / bench fitting lesson 18 years ago that there is a formula for working out the size of hole required when tapping a thread.
I am planning on using these (M8 Grub screws).
Therefore (Oh cleaver people) what size hole should I be drilling.
Thank you in advance.
Next If I bring my uprights to Stoneleigh could someone bring a M8 Tap to tap the thread in my new holes.
Standing by.
Cheers Ginge
Build Pictures
Old 13th April 2010, 07:30 PM
Land Locked's Avatar
If my failing memory is still functioning a 7mm hole works just fine for std M8 which is 8x1.25
Regards (The mad Sarf Efriken)
Old 13th April 2010, 07:34 PM
gingea1pom's Avatar
Nice one,
If it supposed to be an odd size like 7.2mm just say as I have a rare selection of drill bits.
Just need someone with an M8 tap now.
I appreciate it might be a little far for you!!!!
Cheers Ginge
Build Pictures
Last edited by gingea1pom : 13th April 2010 at 07:36 PM. Reason: realising we are a global forum
Old 13th April 2010, 07:38 PM
Just Google for "tap drill sizes". It's a 6.8 mm drill for M8. In general, the formula is D - 1.08 * p, but some lists recommend D - p. (D -- outer diameter, p -- pitch).
Old 13th April 2010, 07:39 PM
http://www.engineersedge.com/manufac...rill-chart.htm
Old 13th April 2010, 07:55 PM
gingea1pom's Avatar
Cheers men,
Thanks TT, obviously I could have done that myself but didn’t so other forum members would benefit.
I know it is probably imposable to see from the picture and I should really give them a bell in the morning but does the grub screw in the picture look course or fine.
I am hoping course as it can only be one hole size opposed to the three hole sizes for different pitches of fine thread.
This kit car building is a mine field
Build Pictures
Old 13th April 2010, 08:01 PM
Enoch Enoch is offline
If you are going past Bracknell in the near future bring em along and I can drill em and tap em for you.
Dave.
Old 13th April 2010, 08:13 PM
gingea1pom's Avatar
Enoch,
What are you up to on Thursday; I have a free day, if it’s not too much bother.
Cheers Ginge
Build Pictures
Old 13th April 2010, 08:39 PM
Hi Ginge,
Build is looking good on your build thread.
They look like course threads on the grub screws, Depth of thread = 0.866 of the Pitch of the thread so 8-(0.866x1.25)=7.02mm so a 7mm drill would be fine for the M8 thread. Plus the cast of the upright taps easy.
Keep it up....AndyH
Old 13th April 2010, 08:54 PM
mark mark is offline
You can get a cheap tap and die set that goes from m4 to m12 for about £25 it will even have the wrenches in
No good for everyday use but fine for the odd bit whilst building your car
