As i have some spare cash from selling my bike, i'm going strip my 2l pinto engine completely down as i have no history on the engine.
What i need to know what should i be replacing or doing to the engine i.e. inlet and exhaust valves and seals head skim piston rings Cam? all advise greatfully received ![]() Terry |
What are your overall plans for the engine? Are you going to swap it out for a zetec engine later on, or will you just be sticking with the pinto? If its the former, then you may want to hold off spending money on the engine, as it could end up being a bottomless money pit.
I got my hands on a 1.8 CVH which i stripped down and was planning on rebuilding, it wasn't a runner and required at least £150 to get it going with a complete rebuild. I managed to buy a 94 1.8 zetec engine which is a known runner for £40.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting
At the moment i'm going to stick with the pinto, the engine did run before i removed from the donor.
Terry |
Your not going to know till you rip it apart.
But for a full rebuild Bottom End Gasket Set Breaters Crank check and grind if needed Main Bearings to suit Big End Bearings to suit Oil pump Strip, clean, check and replace if needed Bore Hone or rebore Pistons to suit Rings to suit New water pump Top End GAsket Set Head skim Cam Bearings Valve Seats for U/L Valves to suit New guides New springs Rockers checket and replaced Cam Replaced Oil Spray Bar Restud Manifold faces Cambelt That's about it. TT
If the Pinto was running OK when removed from donor then just replace oil and filter, (you've got to drain the sump to mod it anyway) and fit new plugs and leads. set valve clearances and LEAVE IT ALONE!
Go any further and it'll cost big bucks and it ain't worth it! Last time I rebuilt one to fully recon. spec like TT's list, (in 2006) it cost nearly a grand. For a tenth of that you can get a good silver top Zetec which is more powerful straight away. BV. ![]() And since you need £1400 for the SRi you won't have big bucks to spend on the Pinto ![]() Last edited by Big Vern : 10th May 2010 at 08:08 PM. |
Bolt the engine and box together put the starter in and do a compression check,it will give you some idea of the state of the internal's.
My Usual is..
See if it runs on the garage floor. If yes then fit it , if no buy another. Once in if it seems ok then just use it and see how it goes. TT
Quick update,
Head is being skimmed Crank is being polished The bores are being honed (if thats the right word) All for £80 then i will sort out piston ring and bearings when i get the big bits back Terry |
£80 wasted when you could have bunged a zetec in for an instant upgrade in power, economy & reliability.
Mate of mine has just sold a zetec with shortened sump and flywheel, clutch etc for £40, I've just picked up a 1999 1.8 zetec for NOWT! LG, Steve |
