Hi all advice please, is the Sierra estate as good a donor as the hatch back ? Is there any advantage having one over the other ?
Thanks. |
The Sierra Estate will be fine for a donor
All of the running gear is the same as the Saloon & Hatchback. The rear subframe is laid out a little different on the estate but the hubs, drive shafts, diff & brakes are the the same. That said, if you really want disc brakes on the rear of your build you'll be more likely to find them on a Saloon/Hatchback.
I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk Last edited by Bonzo : 21st August 2010 at 07:47 PM. |
Hi GT,
As Ronnie has said, a sierra estate is fine as your donor, my donor was a 1.8CVH/Type 9 gearbox estate, no probs at all for my build, cheers andy |
Cheers guys - another question - are any of the 4 x 4 models useable - guessing some mods may be required ?
A fair bit of the running gear on the 4x4 Sierras is useable.
The front hubs will need replacing as they are not suitable for the Roadster & there will be some engine mods to do. I am sure TT will let you know the full range of engines available on the 4x4 Sierra. If a Limited Slip Diff floats your boat the 4x4 is not such a bad option ![]()
2.0 DOHC
2.0 Cosworth 2.8 MFI 2.8 EFI ( Rare ) 2.9 EFI Only mod needed on the engien is a swap to a 2WD Sump unless you fancy welding the ALI. Gearbox will be useless as it combines the transfer box. Rear drive train is fine. Front hubs can have the outer CV removed, so they may be useable but the geometry on the 4x4 is a little different to the 2WD so they still may not fit. TT
Ok - options for the donor are increasing - another question (to increase possibility of donor at good price) -does the P100 pickup have the same running gear ?
Cheers for all the replies so far - appreciated guys. |
It has a solid rear axle so no independant diff or hub carriers, and the front uprights would be 5 stud. So only the engine and box are likly to be of use ( if it's petrol )
hey guys - there's no going back now - just picked up a 1.8 estate
Picking up on the sierra 4x4 thread. Has anyone ever done a 4x4 build, and what would it be like
