|  2mm thick steel cutting? Hi guys, Am I right in thinking I need to use a thin grinder disc to cut this or could I use a jigsaw? Thought i'd ask before I make an almighty balls up!!   Cheers Russ |
|   I used 1mm thick slitting discs (very thin grinding discs) they slice through 3mm thick steel like a knife through butter. I have used 5 discs to cut out all of my chassis plates and do a lot of other jobs. May i ask what you are using the 2mm steel for?
				__________________ 1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting   |
|   yeah, course. i've been given it to use for my floor panels |
|   that's going to be heavy! TT
				__________________ You only get a woosh with a dump valve Build Thread Man Cave Mantiques Cecil Street Auto Repairs Garage Carlisle Build Cost £4181.65 - Last - Wheel Cylinders |
|   Will it be too heavy or can i get away with it? It's cost me nothing and i thought they aren't massive bits so wouldn't make too much difference? |
|   Quote:
   It was free....use it  ps... don,t do full welds all in one go, stagger the welding, to avoid heat distortion. cheers andy extra info....Spuds Roadster has a steel floor, doesn,t slow that car down. |
|   Cool, all systems go again. Cheers |
|   I'm told that welding on a steel floor can lead to corrosion problems, and I believe it's actually not allowed in locost racing because of this. I understand the corrosion is caused by there being 2 pieces of metal close to each other that you can't get at to apply rust preventative, and that the thin gap causes moisture to be drawn into it. |
|   Jigsaw cuts it fine and cleaner and easier to control . Dont quote me as I have not verified it but I am fairly sure the MSA blue book requires a steel floor for racing.
				__________________ Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
|   Quote:
 You could well be right, but I have a feeling, I'm sure I read it somewhere, that such floor had to be rivetted on rather than welded. Obviously the rivetting would then allow sealer to be applied to the joint, thus preventing the rust problem |
