Old 22nd October 2010, 09:53 PM
DRCorsa Engineering DRCorsa Engineering is offline
Default New components for the Roadster
Hello to everybody.
I have developed two new performance components for the Haynes Roadster and any Locost 7 car in general. The first one is a double MC pedalbox and the second one is a gearchange mechanism for BECs.
I open this thread to present these products to you and see if there is any real interest.
PEDALBOX
Double MC with balance bar design. The design is very different to the book's one and is quite more advanced with both accelerator and clutch cables featuring a bellcrank mechanism (rotating on ball bearings) giving you quite a few options to alter the pedal's response and stroke.
The pedalbox is provided fully powdercoated and any parts left unpainted are made of AISI 304 stainless steel.
Both accelerator and clutch pedals have double stops to set their start and stop positions according to your requirements.
Any pedalbox will be made according to anyone's requirements. Anyway, Haynes chassis is unique, so the design will be the same for all of you, but for those owning different chassis, there is the possibility to have the pedalbox suited to their chassis.
The pedalbox will be TIG/MIG welded, comes powdercoated and includes everything needed except for the balance bar and MCs.
Uploaded with ImageShack.us
BEC GEARCHANGE MECHANISM
The latest design is a high quality gearchange mechanism for BECs. The gear knob will be aluminum CNC machined. The gear lever will rotate on two needle bearings which will give perfectly smooth operation. All brackets will be laser cut and TIG welded. It will also come powdercoated.
