Old 5th November 2010, 01:55 PM
misty misty is offline
Default master cylinder
OH another problem
wanted to have a brake pipe going to each wheel , so i bought a master cylinder from a sierra that had disc brakes all round , asked the mecanic he said brill that is good.
master cylinder just arrived wow it is a little big has anyone fitted one before could give me a few tips
Old 5th November 2010, 02:07 PM
Sounds to me like you have one with a servo.like this
http://cgi.ebay.co.uk/SIERRA-BRAKE-M...item33622dcb76
you want one like this
http://cgi.ebay.co.uk/New-Ford-Sierr...item3a5ffecfe2
Old 5th November 2010, 02:09 PM
axle's Avatar
axle axle is offline
Hi
It has been a while since I Have done this, the two ports at the front one goes to the o/s and the other to n/s the one at the back to the rear spiliting with the T-piece going to the r/n/s & r/o/s.
I hope this is of some help and some else can correct me if I am wrong!!!!
Regards Axle
Old 5th November 2010, 03:19 PM
Originally Posted by misty View Post
OH another problem
Not got an ABS one have you?
The all sierras use the same single circuit to the rear and split left & right front. There is no sierra with a 4 way split.
Old 5th November 2010, 03:32 PM
axle's Avatar
Red face
Hi There
No ABS, what I have tried to say was three ports. 2 for the front and 1 for the back, correct me if I am Wrong?
Regards Axle
Old 5th November 2010, 03:52 PM
this is what i have
[ATTACH][ATTACH]1016
[/ATTACH][/ATTACH]
Old 5th November 2010, 04:02 PM
Andy_B Andy_B is offline
this is what i have
[/ATTACH][/ATTACH]
Exactly the same that came off my Granada Scorpio...its got the servo and ABS System attached to it....mines going on Ebay along with the Brain totry and raise enough money for the one quoted previously ..
Old 5th November 2010, 04:05 PM
That master cylinder setup will be no good to you. You want one from a non ABS sierra. Have a look on ebay you can sometimes pick them up second hand quite cheaply.
Old 5th November 2010, 06:25 PM
New M/C are only about £30, well they were when my car got a new one earlier this year.
Old 6th November 2010, 10:38 AM
rapidtornado's Avatar
can you remember where you got it from Andy? I need the same set-up as noted above (3 port) and I'm looking at £80+ for an m/c (all round discs) so will be getting that unless you can direct me to the 30 quid supplier
