Old 11th January 2011, 11:24 PM
Default flat pack offer
Knowing that builders out there have various size of budget and differing build times I thought I'd offer two levels of flat pack. The first being a basic chassis which stops at RS14 and the second being an a near complete flat packed rolling chassis including diff mounts ,wishbones and rear uprights.
All chassis tube angles 45' - 90' are cut with a cold saw so no chop saw blade wobble giving 1-2mm variations. All chassis compound angles and wishbone tubing are cut on a mill.
The basic flatpack will comprise of:
the main chassis up to RS14 all in 25x25x1.6 ERW box
the transmission tunnel for a type9 box (this can be trimed to make MT75)
rear suspension mounts CP1+2+3+4+5+6+7+10
16 wishbone brackets 4 damper brackets
Total £200 £40p&p
The rolling chassis flat pack will comprise of:
the basic flat pack plus RP1+2+3(bent rear tub tube) D13 CP8
SW1+2+3 CP15 column mount
CP19+20+21 rack mount
Full set of wishbones
profile cut 25x2 and 19x2 CDS
M18x1.5 + M20x2.5 Threaded bushes M20x2.5 stud
44x bush tubes
5mm front plate
2 damper brakets
Rear set of uprights
3mm CNC laser cut RU1+2+3+4+5+6
RU7 pre drilled RU8 tapped to M10
Diff mounts
DM1 pre drilled to match CP10 +DM2
Total £400 £40p&p
If any body is interested please message me throught the forum or email me at talonmotorsport@aol.com
Old 12th January 2011, 12:04 AM
just a quick question. how can a type9 tunnel be trimmed to make an mt75 one? the mt75 is a bigger box so surely it would need more material in certain places. or am i missing something?
My Pictures
Old 12th January 2011, 12:21 AM
Nope, YOU are not missing something Ash.
Old 12th January 2011, 05:32 PM
Type 9 is a smaller box, so the tunnel is narrower and the box sections longer.
MT is larger, so the tunnel is wider and the box sections can be shorter.
