Old 7th February 2011, 09:41 PM
rapidtornado's Avatar
Default UJ Joint off manaul rack
Gents
Anybody got a UJ joint off a maunal Sierra steering rack I could buy off you? Only found out this weekend that the Sierra PAS rack has a different diameter splined shaft to that on the manual sierra rack (which is the same as the MK 2 escort rack)
PM me if you can help
Rapid
Old 7th February 2011, 10:59 PM
do you mean the bit with the rubber disc that clamps direct to the rack input shaft i think i might have a spare one somewhere
Old 7th February 2011, 11:13 PM
I guess so, there is no rubber clamp bit on the one I have but yes, it's the sections that clamps onto the input splined shaft on the rack and triangle shaft/clamp on the other end of the knuckle
Old 7th February 2011, 11:24 PM
i will have to have rumige in the garage when im in there next
