Old 1st March 2011, 10:38 AM
whitstella whitstella is offline
Question zetec engine mounts
hi again
i've got a 2l silver top zetec to fit in my haynes and i was wondering what engine mounts people have used and has anyone got measurements of where to put them. the problem i have is the chassis is at work and the engine is at home and i dont know where it will sit.
cheers steve.
Old 1st March 2011, 11:32 AM
Your a million times better offering the engine and gearbox up to the chassis. Your engine location is important, but your gearbox, bellhousing and clutch lever positioning is also super important. You may end up making a mount that you then have to move 20mm to clear something else.
I found out the had way
Old 1st March 2011, 11:37 AM
Default cheers
could i weld plates from br1 to br8 (and otherside) like large triangles and mount from there????
Old 1st March 2011, 11:57 AM
Ashtonr Ashtonr is offline
I'm at the same stage as this and was wondering how far forward from tr8 the back of the engine should be alos the height between the bottom chasis rails and the centre of the crank most people have mounted their engines. I have the Engine in place at the moment but there quite a lot of room to position it.
Rob
Old 1st March 2011, 12:00 PM
This thread seems to give some detail http://www.haynes.co.uk/forums/showt...ngine+position
Old 1st March 2011, 01:14 PM
tex tex is offline
you will be better off hanging the engine and box in the chassis [free dangle] to get the position right to clear all obstructions - then make your own mounts using 2" box tube with flat plate. use card to get the angles right
Old 3rd March 2011, 10:57 PM
onedayTM onedayTM is offline
Hi guys, whilst reading this about positioning engine, I too have zetec lump, I never made a note when I removed it from donor, does this engine sit level because quite afew motors have small lean angles?
Anyone know anything.
tony
Old 4th March 2011, 08:55 AM
Hi Tony
I have just had a look at the Zetec engined Mk5 Escort sitting in my drive.
The engine looks to be more or less, dead level ( Upright ), if it has an incline it must be very slight
I suspect the Mondeo would have a similar engine placement.
Old 4th March 2011, 09:37 AM
tony
If you ever have any doubt over an engine that you think leans, check out the sump. All oil pans will sit horizontal. If the sump is horizontal, so is the engine.
Old 5th March 2011, 07:29 PM
I don't think this holds true to Zetec on Mondeo. The engine sits vertical or very hear vertical, but the bottom of the sump has a rather steep incline:
Curiously, Escort sumps have a flat bottom.
