Old 18th March 2011, 07:32 PM
Andy_B Andy_B is offline
Default Pics..Fuel and Brake lines ..Enough clips ??
Been hard at it today..had a rethink of my fuel feed and return lines so made a track for them to run down....i hate feckin microbore pipe it may be malable but in my big plates of meat it is CRAP hate it !!![IMG][/IMG]
Have i clipped it enough...cant move the pipes unless you wedge them with a scewdiver !! There are a few bits of the petrol pipe i want to cover with split rubber but will need to scavange some tomorrow at work thing 6mm 4 core SWA insulation is about right
Old 18th March 2011, 08:36 PM
More than enough should keep the man happy.
Oberservation and not critical,you could have put 2 clips on one rivet for the brake pipes at the front.
Old 18th March 2011, 08:45 PM
Story of my life mate...my rivets were to wee !!!
Old 18th March 2011, 08:48 PM
Looks really good Andy, use of the rubber lined p clips always goes down well with the IVA man and the way you have rubber lined the copper tube at the corners looks good to.
Plenty of clips.....
Andrew
Old 18th March 2011, 08:52 PM
Ken the problem Andy,wee rivets are a pain.
Old 20th March 2011, 09:00 PM
steve8274 steve8274 is offline
hi
is that 8mm or 10mm microbore?
got some 10mm lying round from central heating. wasnt sure if i could use that.
thanks
steve
Old 21st March 2011, 07:51 AM
yeah its 3/8" microbore...had a coil of it lying around so thats why i used it too !!
Old 24th March 2011, 08:51 PM
DONT USE 3/8" MICROBORE !!! as i needed to do some tight 90 bends to look nice and neat around the engine bay...can you get 3/8" end feed or yorkie fittings....can you f@@k ...all my days work has been ripped out and ran in 10mm od pipe...on the bright side i have a supply of rubber petrol pipe which will fit over the microbore very snug...
