Old 26th April 2011, 09:33 PM
Default omega donor pedal box
hey guys just wanted to post up my pedal box i had a fiddle this weekend and this was the result
it uses the std bias master cylinder from the omega (minus the servo ) and the std clutch master cylinder from my donor
Old 26th April 2011, 09:59 PM
Just what this forum is all about ingenuity,nice one Rob.
Old 26th April 2011, 10:15 PM
thanks
erm better sort the links out just had a quick tidy up of the photobucket but its messed me links up bear with ..............
Old 26th April 2011, 10:20 PM
Did wonder what was going on .
Old 26th April 2011, 10:31 PM
links sorted
littlun makes these jobs last far longer than id like 10 weeks today she is
small issue to do with my steering arms crashing into my lower wishbones on severe lock but im still going fowards
fuel tanks next on my list incorporating the omega fuel pump which handily has a swirl pot built in, also the return feeds directly into the swirl pot/ pump it will be in steel tho as i have never tried ali welding and cant afford the equip even tho i have enought ali lying arount to make a few nice tanks
Old 26th April 2011, 10:35 PM
Know the feeling,my grandaughter is four months but no reason for my build slowing down just cant find time with work and play.
Old 26th April 2011, 10:43 PM
i just got a promotion too at work so 10 wk old extra coursework to go with team leader course and paying back hours at work im surprised ive had time to get this done soon as i start the first assignment im sure work will slow (for an hour or so ....)
Old 12th May 2011, 08:08 PM
phil clegg phil clegg is offline
Default pedalbox
like your work with your pedalbox,but it would appear your pedal ratio is not high enough,needs to be at least 5 to 1,check out obp website or rally design,having done it wrong myself its better to check before you fit,goodluck
Old 13th May 2011, 09:35 PM
MMm? wasnt aware it had a calculation !!! I just made it all fit hope theres not many more of these calcs ive built the whole car by winging it and making it fit !! ;-)
