Old 13th May 2011, 09:44 PM
kitcarkid kitcarkid is offline
Default full cage
hello i need some help, i am thinking of starting a haynes roadster
just having a few thoughts,
i want a full roll cage that has a windscreen built inand will be completly water tight when a hood and sidescreens are attached
any one know where i can get this made, or possible suggestions??
the type of full cage i want is like the mk indy (bars above head are centred) for easier access, my car will only be used on road (if that helps when planning the cage)
Old 14th May 2011, 10:02 AM
Are you looking to be able to remove the roof and doors and leave the roll cage and screen on or will the roof be perminantly on the car?
If your planing the former then it will never be water tight, little short of chauking round all the joints it will leak to some degree. If you go for the later then just bond the roof section to the body work.
There was a car based on vauxhall parts with the engine mounted at the rear called the Cyclone made by Carcraft, it had a square nose and a tessarosa style back end. It had a removeable roof section and removeable gt40 type doors.
Old 14th May 2011, 10:04 AM
MarkB MarkB is offline
There was a car based on vauxhall parts with the engine mounted at the rear the name of it escapes me at mo but that had a square nose and a tessarosa style back end with a fixed roof and removeable gt40 type doors. I'll have a look around and see if I can find a pic or to.
That will be the Cyclone and was made in Blackpool and a very pretty car that was, sadly no longer made and the moulds went in the bin!!!!
There is a blue one that hillclimbs and sprints in the South West and damn quick it is too..
Old 14th May 2011, 10:36 AM
You must have been typing while I was faffing with photobucket. I realy liked the Cyclone it was some thing different 12-14yrs ago amongst a sea of fake snakes and 7's.
Old 14th May 2011, 11:01 AM
There were two parked up at Stoneleigh,quite big cars compared to a 7 but so much prettier. Like I said there is one raced in the South West which considering the moulds are no longer is a very brave thing to do...
Old 15th May 2011, 05:21 PM
thanks guys but wanna stick to 7 style i prefer them.
Old 15th May 2011, 07:48 PM
I was talking about the style of the roof not the whole car,
Old 15th May 2011, 09:48 PM
les g les g is offline
you would be quick up a hill mate
if you had a trick s2000 engine in you
cheers les g
