Old 25th December 2009, 07:31 PM
Default Weights of Sierra components
Today I weighed the various Sierra components on a bath scale out of curiosity. I guess these numbers might be useful to someone. These bits came off a 1987 2.0 carbed Sierra sedan.
Bare rear subframe with rear rocking arms 33 kg
Final drive 21 kg
Front hub with a caliper (Teves) and a disk 13 kg
Rear hub, drum brake (Girling), bearing carrier, spindle, cable 11 kg
Propshaft, with middle bearing 8 kg
Half-shaft with both CV joints 6 kg
Steering wheel with upper half of the steering column 4 kg
Steering rack, with tie rod ends and the lower column part rusted on 5 kg
Old 26th December 2009, 12:46 PM
gingea1pom's Avatar
Will be useful later cheers.
Build Pictures
Old 6th September 2010, 10:22 PM
What you see here weighs around 260 kg... Hard to believe, considering that the bare chassis weighs only 70 kg, but nevertheless true.
