Old 8th August 2011, 05:28 PM
MikeB MikeB is offline
Default Counter Sunk Pop Rivets for Floor
Going to put my ali floor in hopefully this weekend.
I'm sure I read the sides should use counter sunk pop rivets to give clearance for the side panels, what rivets have people used? and what countersink tool?
Mike
Old 8th August 2011, 05:55 PM
Deanno's Avatar
Deanno Deanno is offline
good question, also i'm guessing the rivets have to be sealed rivets or do youuse normal ones and put some silicone in the holes??
Dean
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 8th August 2011, 06:37 PM
Talking
Get the rivets from a decent nut and bolt shop and ask them where the price break is on quantities . Some times you you get 500 for the same price as 250 as an example. If you are doing a lot invest in a drill and countersink as one unit.
http://cajero.co.uk/countersinks.htm
Old 8th August 2011, 10:18 PM
when I bought some rivets I found that screwfix were really cheap for 500+
Old 9th August 2011, 01:20 PM
Can't find any countersunk rivets in screwfix?
Old 9th August 2011, 04:51 PM
a good deburing bit makes a great countersink in the drill
a large drill is useless as it has 2 cutting points and will make triangle shape countersinks
