Old 7th August 2011, 07:13 PM
Deanno's Avatar
Deanno Deanno is offline
Default Aluminium sheet
i'm coming to the stage where i need to buy the aluminium (when money allows).
what sort of price have people paid as i'm not sure on what is a good price?
I have plently of 1-2mm steel off-cuts in work enough to do the tranny tunnel sides, would this be too heavy for the sides of the car do you think???
any help is good help
Dean
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 7th August 2011, 10:02 PM
http://www.aluminiumwarehouse.co.uk/...duct_info.html
worth getting the stuff with the plastic film on.
bob
Old 7th August 2011, 10:24 PM
If your tight for funds or on a budget use 1mm steel for the sides,tunel,back etc and 2mm for the floor(s). As for weight I would'nt worry as the average passenger weighs 60-80kg and you can always fit a bigger engine. Besides a little extra weight is not always a bad idea as it will put some much needed heat in the tyres.
Old 8th August 2011, 09:00 AM
Wgroove Wgroove is offline
And what do you use for floor, tunnel, back etc, if you're not on a budget ?
Regards,
Wim
Old 8th August 2011, 09:15 AM
Deanno's Avatar
Thank you for all your reply's
Dean
Old 9th August 2011, 04:54 PM
found here was ok for cut sizes http://www.clickmetal.co.uk/
