does anyone know about trailer axles and extending them? recently acquired the below for £100 delivered and am planning on turning it into a car transporter. unfortunately the wheels are too close together was originally going to put some spacers on the wheel but these would need to be 75mm each which would play havoc with the wheel bearings so the only other option without adding loads of weight would be to extend the axles. does anyone know if this is possible with this type of axle? and how much work it would take? don't want to spend a fortune on it so...
any advice much appreciated ![]() ![]() Edit: found a little info on google but not 100% if it applies to this kind of axle, dont want to start cutting and something go wrong if they have a torsion bar in the middle. Ta Very Much JakeH
its reight! is not a suitable measurement! Last edited by JakeH : 24th August 2011 at 03:34 PM. |
Look like torsion unit's to me.
Can't really see from your photo but if they're AlKo axles they can't be altered as they have torsion springs inside. If they're separate indespension units bolted onto the main axle bar then you could cut it in the middle and weld in a new section to widen it or just replace it with a longdr beam.
D.
visit my website at www.cossie.davenewell.co.uk |
