Old 1st September 2011, 05:35 PM
mark100 mark100 is offline
Default indipendent rear end
Just a quick one
How easy is it to convert a solid rear axel frame chassis to the irs
would it be ok to get a part finished project of the older type back end and update it to the indipendent i was thinking as the rest of the car is prity interchangeable is this ??????
Old 1st September 2011, 05:52 PM
Homersdouble's Avatar
Homersdouble Homersdouble is offline
Originally Posted by mark100 View Post
Just a quick one
I have done exactly as described. I was part way through my roadster chassis build when I was given a much more complete live axel chassis. I then proceeded to chop off any tubes behind the seat back frame and re-instate with an IRS based as per the roadster. There are a few things to consider though;
The live axle book chassis is 2" ? narrower and 1" shallower - Roadster bodywork wil not fit.
The seat back frame is of slightly different angle - some changes to diff mount frame are needed.
The front frame may also be slightly different - I had to make shorter top wishbones.
Hope this helps, Chris
