Old 20th November 2011, 09:06 AM
eSteve's Avatar
eSteve eSteve is offline
Default Pinto engine gasket set and oil seals
Hi,
hav'nt posted for a while but been bimbbling along with the build. Have fitted engine. Well, made up some engine mounts and welded the engine & g'box AV mount supports in place and then promptly removed it for some TLC.
It was not only grubby, but has a few leaks on front & rear crankshaft oil seals and cam shaft cover. So I've stripped it down for a paint & oil seals and cam belt.
Can anyone recommend an online supplier of a full gasket set, and oil seals (front & reas CS, aux. shaft and cam shaft), that they have used and found to be good on price and service?
Also, can anyone tell me the part numbers for the four oil seals and cam belt?
I have a 1.6 Pinto, engine number KM87098 from a G-reg. 1990 Sapphire.
Thanks,
Regards,
eSteve
