Old 5th February 2012, 04:36 PM
andysredmini andysredmini is offline
Default Diff Plates Flexing MX5 based saturn chassis.
Has anyone beefed up the diff plates (cp26)?
I have just tacked mine on and they can be flexed by hand.
I know this will reduce when fully welded but im considering replacing them with 5mm and cutting down d12 to suit.
Should I bother or leave them as they are?
Will it have a knock on affect on anything else?
Andy
Old 5th February 2012, 05:02 PM
Aren't they supposed to be 5mm anyway? I'm pretty sure that's what Spud told me to use when I did mine.
Old 5th February 2012, 06:46 PM
stew stew is offline
i used 3mm, thats what spud's guide said. was a bit in the same boat about the flex, but reckon it will be ok. if not ill strengthen them up!
u use 5mm john?
Stew
Old 5th February 2012, 07:09 PM
Hi,
Should be an easy fix if you are worried about it. I will have a look tomorrow on my chassis and if it is a problem I wil probably press up a "U" profile joining both diff mounting points and also bolt down to diff plates around the diff mount.
I made mine from 3mm steel as per the drawings and my chassis is painted so wouldn't like cutting and welding parts to it now.
Old 5th February 2012, 07:46 PM
Thanks for the replies. It definitely says 3mm in the guide, page 2 i think.
Did you use 5mm then skov? if so, no problems further along in the build?
(i know its only 2mm but you never know).
Old 5th February 2012, 08:41 PM
I think I used 6mm! Might be a tad heavy, but it certainly doesn't flex
Old 5th February 2012, 09:19 PM
That should help as a retro fit.
Im going to make some 5 or 6mm plates at work tomorrow.
I can do some extras if anyone wants some.
Old 5th February 2012, 09:28 PM
Gear Monkey Gear Monkey is offline
Here is the back end I'm building.
http://flic.kr/p/bp7ffX
http://flic.kr/p/bp7fbR
Paul
Old 5th February 2012, 09:51 PM
ive not hauled my diff out yet, but is there any pics of them, would it be possible to weld in some 25*3mm flat in line with the inboard ends of the diff mounting plates, meaning that the diff mounting holes would be 3mm recessed, but would add the required rigidity?
just an idea....
Stew
Old 5th February 2012, 09:59 PM
Here's some pics of my 1.6 diff if it helps Stew:
