Old 21st July 2013, 05:43 PM
jateu01 jateu01 is offline
Default Engine Recommendation
Hi ladies and gents,
Look for some guidance , will be using emerald ecu and don't wish to use a bike engine. Not looking for wishlist just recommendations .
Many thanks .
Old 21st July 2013, 05:58 PM
Oscar Oscar is offline
Oh dear, you may have opened a can of worms here!
The Roadster has been built with so many engines now it's kinda down to choice. Theres everything from the standard Pinto as per the book up to a V6 thats been shoehorned in!
Whatever's chgosen will require variations to the design, and I don't think anyone on here will be able to give you a definite: this one is better than any other because... (Except maybe the V6 )
I'm using a 2l DOHC cos thats what my donor came with. This is the usual way of working, so you'll probably get a few reccomendations for the mx5 engine now too.
I haven't really helped much have I?
Photos of the project so far:
Old 21st July 2013, 07:26 PM
Dualist's Avatar
Dualist Dualist is offline
What power are you looking for.? Any budget.?
I'm using a rx7 rotary, but if I wasn't I'd go for the Mazda v6.
Old 21st July 2013, 08:26 PM
I'd say, unless you go the MX-5 route altogether, or stay with the donor Pinto or CVH, Zetec is a good choice. Easy and cheap to get ~160 bhp out of it (bike carbs and a reasonable exhaust), and ~180-200 is not far off, too (fast road cams and bike throttles). Will mate with the Sierra gearboxes without much trouble. If you break it, the replacement will set you off ~100 quid or so.
So, definitely look at the Zetec, unless you have an aversion to four pots or Ford engineering.
More info here: http://www.toyne.org.uk/zetec.html
Old 22nd July 2013, 09:52 AM
I'm not looking for a wish listjust what every one would recommend for engine type or better still what you have used. I know that the mx5 engine is a direct copy of the ford duratec engine. In all honesty I would like the 1.6 corsa vxr engine. Any one used that and can any one advise of any issues with the 1.6 vxr engine
Old 22nd July 2013, 11:19 AM
Eddy Eddy is offline
Anything is possible and it is very much a case of personal preference.
I've not got any experience of the VXR lump, but I think Westfield have used it, so there should be some info on it around the net - Which bellhousing/gearbox to use, engine mounts etc.
Being a turbo, theres another system to worry about and route around everything else compared to an NA set up.
I suppose it depends if you want a journey of discovery or a known solution
Old 22nd July 2013, 06:52 PM
PorkChop PorkChop is offline
As said, it depends on what gearbox(es) you have available, what your intended use of the car is, your budget, how simple you want the build to be, what you fancy...you don't necessarily need to be limited by using an Emerald (or any other standalone) ECU and the possible expense of making it work with whatever engine you end up choosing. However, you do have the luxury of not needing to fork out for a standalone should you need to go down that route.
I'm on my third or fourth engine choice ATM, but my decision is partly motivated by what class my car would be in for sprints & hillclimbs whilst maintaining a sensible budget, plus what other running gear I have available.
The MX5 MZR engine (found in the Mk3) is the same as a Duratec and therefore a MZR gearbox would fit a Duratec. However, they are a different bolt pattern to mark 1/2/2.5 MX-5 gearboxes and AFAIK not interchangable. Mk 3 boxes still command a healthy premium, unlike 5 speed mark 1 MX-5 gearboxes, where they seem to be cheaper than Type 9 boxes.
The VXR engine is used in the Westfield Sport Turbo, with an MX-5 gearbox (I don't know whether an adapter plate would be required, but I'm guessing so). You're looking at a 4 figure sum to buy an engine from a breaker though, due to its newness.
Old 24th July 2013, 06:41 PM
As others have said aside from size considerations it is very much horses for courses.
All engines cost quite a bit to rebuild even to standard spec for standard performance.
Engines that have not been fitted to production cars for several years are still available but are more likely to need a rebuild. If you go for a later type you are more likely to find a serviceable condition 2nd hand engine for reasonable money.
This cost increases if you are including performance improvements. Significant gains generally cost significant £s. Beyond a certain point you may have to look towards specialised rods, pistons and crank to handle the extra power.
Mating an engine to a rwd gearbox it wasn't designed to fit can almost always be done so long as it can handle the power- but will need an adaptor bell housing, the right flywheel and clutch and in some cases the gearbox input shaft will need machining down to fit the crank end/ spigot bearing. You dont need to be limited to a Ford type 9 box though if you can find a good and affordable rwd gearbox that will bolt straight up to that engine.
After market carbs, manifolds and ignition systems can really add to the cost of that engine choice. A fortune can be saved if it is 1 practical and 2 adequate to reuse these systems from the donor vehicle.
Sump. Due to the height of many engines it's often necessary to buy or make a modified sump and oil pickup pipe. A few engines will go in without the need to modify these though thus saving a bit of money.
Old 26th July 2013, 08:51 AM
Enoch Enoch is offline
Jag V12 every time
Seriously though, if I was looking for an easy build, at a sensible price, with a reasonable lump of power I would definitely go for a Zetec. They are plentiful, mate up easily to Ford boxes, they are cheap, reliable and tunable. You can't ask for more really.
Old 26th July 2013, 02:33 PM
Don't know a great deal about the newer VX engines, but it may be worth investigating whether the small turbo lump will mate to the VX Omega box.
The Omega box (i believe) is a Getrag box and more than adequate to handle the power.
I intend to use it mated to an X20XEV from my old Vectra showcar.
