Old 31st March 2012, 09:18 AM
misty misty is offline
Default plumbing the 2lt pinto
Hi all
I have a 2lt pinto installed with a 2 pipe only rad.
Now, I have the header tank high on the bulk head
1 large outlet from the header tank and 1 small
BUT where do the pipes go to
I do not have a heater
Help!!!!!!!!!!!
Old 31st March 2012, 03:13 PM
Check the cooling system pipework from the head which would have run to the heater in the donor. This is often just turned into a closed loop when a heater isnt fitted. This pipework also would have gone to the autochoke on the original downdraft Weber carb.
Old 1st April 2012, 07:32 AM
sorry no donor, no heater, no manifold inlet, no small outlet pipe on the pump, any help would be great
Old 1st April 2012, 09:23 PM
silvertail silvertail is offline
Hi Misty, the link below shows how my Pinto (EFI, not carb) was plumbed, hope it helps!
Old 2nd April 2012, 08:26 AM
If the rad only has the two connections you will have to cut a double tee into the bottom hose to the rad. One of the pipes from the bottom hose goes to the header tank and the other to go to where the heater pipe came from the head or manifold, that then is the bypass taken care of and if you fit a heater at a later date thats where you will get its feed and return from. then all you need is the purge pipe from the stat housing to the expansion tank.
