Old 25th March 2012, 09:58 PM
nath nath is offline
Default CVH Coolant Bypass Pipe
Hi Guys,
Can anyone tell me if this need blanking off? (Top, Front of engine)
It's a 1.8 CVH with ZX6r bike carbs and I am using the 1.4 CVH thermostat housing on the rear of the head. The Haynes manual says it is for the coolant bypass hose but I'm not sure if it needs blanking or should be plumbed in
Thanks,
Nathan
Old 26th March 2012, 09:37 AM
brainbug007's Avatar
I'm using exactly the same setup as you and I blanked this off. It's only really for coolant re-circulation to help the engine warm up quicker but it would have been more hassle to plumb in that it was worth imo.
Old 26th March 2012, 09:59 AM
MikeB MikeB is offline
looking good, same set up as me. I'm just starting on my cooling system so can't help with the question.
Could you post a picture showing the coolant pipe layout and what size bore and bends and where you sorced the straight stainless pipe etc
My thermohousing has the smaller pipe that bypasses the thermostat, broken off. Not sure it it will be possible to drill the remains out and push fit something else in. Failing that has anyone got a spare housing going?
Old 26th March 2012, 11:30 AM
You could probly pickup a new housing farily cheap at your local breakers, failing that check ebay.
Old 26th March 2012, 12:47 PM
do local breakers exist anymore
Have been looking on ebay, the odd one that appears it £25 up.
I paid about £3 for mine so just want another cheap one really.
Old 26th March 2012, 01:18 PM
Mike,
Below is a picture of the coolant system I am running on my 1.6 cvh with bike carbs.
The only thing you can't see is that the header tank fills the system through the port in the radiator where the fan switch would normally screw in.
Old 26th March 2012, 01:33 PM
i think the 1.8 is slightly different, the water pump exist pipe at the front doesn't have the small vertical pipe I think. Other than that its prettey similar,
Any shots with the nose off?
Old 26th March 2012, 01:39 PM
its ok I've looked on your photobucket.
I see you're running a bike exhaust, I've just used a cheap one for now but if its ok would use it permantly with a better linke pipe made out of stainless.
I was worried about the bolts and IVA that link the pipe to the can.
Do you think yours will pass?
Old 26th March 2012, 04:47 PM
Mike,
I turned the hex on the bolts to the minimum amount to get a spanner on. It is all dome now!
Providing the sphere won't touch it it should be fine. Failing that I'll thread lock ordinary bolt on, and put nut covers on them.
Old 26th March 2012, 09:08 PM
Phew...I thought I'd have to do a load more messing about ...Did you just use a normal hex bolt to blank it off?
