Old 24th March 2012, 06:30 PM
BackyardRacing BackyardRacing is offline
Smile roadster vs locost?
Hi all, first post noob here!
been lurking for a while, and ready to take the plunge, and wanted a little advice from the guys in the know.
im currently stuck with deciding whether to start from scratch with a roadster build, or buy an original locost, (theres a couple on ebay look like good starting points).
i know the roadster has IRS and the locost is live, so im guessing the roadster will handle better, be more agile?
i dont like the "wide body" cars, and im not a big guy, so i want a slim looking car, as close to the original seven design as poss in appearance, but with the best possible handling, so im a little stuck on what to go for, as i believe the locost is slimmer (truer to the original design) than the roadster, and if i pick up an "unfinished car" i can save a fortune.
i was thinking maybe i could reduce the width of the roadster to make it look more like i would prefer, but then no body-panels will fit i believe?
on a second note, i cant weld, so would probably get a pre-welded chassis, i have noticed talon fabrication make these, has anyone from here bought a chassis from talon, any reviews of the quality?
not doubting anyone, just looking for some input, more to put my mind at ease i suppose being such a critical part of the car.
also i believe the locost will end up a tad lighter than the roadster, which must be a + on the performance/handling debate
thanks in advance, Ant
Old 24th March 2012, 06:46 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
The roadster is only 4 inches wider than the caterham you could build the roadster narrower however as you said you then have the challenge of having to make or adapt bodywork to fit the locost is an old design now and you would have to source the mk2 escort and good luck with that on a budget the roadster is sierra based however these are thin on the ground now thats why a lot of people are starting to use the mx5 as a donor
Cant speak for the quality of talon's ready made chassis have only seen the ones that nathan at nts engineering search saturn sportscars and the look spot on to me
Hope this helps
Old 24th March 2012, 07:33 PM
yes, having owned a mx5 (mk1) for a couple years, i was tempted to go that route, as there great handling cars out the box, just seems a little more complex than the sierra based car, more wiring? and seems like it would certainly cost more, being my first build i thought maybe best to keep things simple/cheap.
Old 24th March 2012, 08:08 PM
Eternal Eternal is offline
I had the same problem 2 years ago. The fact that the Locosts are getting kind of old helped me decide on the Haynes, The fact that a well established mx5 design is fantastic as in my mind these are the best donor around today.
The looks are not too wide when you see them in real life. To fix this i added an extra 175mm to the engine bay to stretch it out a bit more(not that it needed fixing!)
In my mind the Haynes has way more pros than cons compared to the locost. Also the community is fantastic! You should come to Stonleigh show and see some in the flesh. Im hoping to get my one down there un its unrunning state
Skyline Roadster
Old 25th March 2012, 10:46 AM
mgglep's Avatar
mgglep mgglep is offline
I can't speak for talon but I bought a chassis from Saturn with wishbones the quality was great every component has fitted first time I bought a chassis really because I felt I didn't have the space to build the chassis
My Build pics
Old 25th March 2012, 11:03 AM
Your car looks super clean, very nice!
Yes I have seen the saturn/nts chassis, there just a little pricier
Old 25th March 2012, 11:22 AM
xBooglex xBooglex is offline
Hi, I to have a talon chasis sat in the garage, the quality and accuracy of the welds are good. I have a couple of mates that are welders and they gave it the thumbs up!!! A decent chap also.
No such thing as a problem just an opportunity!!
Old 25th March 2012, 12:03 PM
Keep this under your hat, close to your chest and super hush hush but I have a 15% off sale on chassis'ies'es running on ebay untill wednesday SSSSHHHHH don't tell any body
Also has any body mentioned that a chassis will go on a car roof rack so collection is not as much of a bugger as people think it is.
Old 25th March 2012, 09:17 PM
MarkB MarkB is offline
A well set up live axle Locost will rung rings round the wider Roadster.
Old 25th March 2012, 09:57 PM
I drove a westie with a live axle <escort> and although it was ok I thought the unsprung weight of the axle was far to much for the car to the point that it was intrusive. The later ones with the sierra running gear ride much better but thats just me talking about a car for the road, track might be different.
