Old 4th April 2012, 07:16 PM
misty misty is offline
Default throttle pedal linkage
Hello to all,
what do the chaps use on the throttle pedal to link the throttle cable to?
Old 4th April 2012, 10:04 PM
Kit spares do a useful little spigot thingy that fits to the pedal with a split pin, and let's you put the cable through.
My Build Pictures:
Old 4th April 2012, 10:33 PM
my throttle cable had a nipple thingy me bob at the pedal end, so I removed the inner cable from its outer sheath, made a small "U" shaped bracket , so that I could drill a hole in it for the cable to be threaded thru ( but small enough so the nipple wouldn,t pass thru it ) & a larger hole on the sides so that i could use a pin & split pin to attach it to the pedal,
once threaded thru the pedal box bulkhead, replaced the outer sheath as normal , worked a treat
Old 5th April 2012, 12:07 AM
now thats the way i done mine but with mine it was rubbing on the bulkhead tube on the other side and was going to wear through so what i was thinking correct me if i do it wrong was to put a clevis pin on the pedal ,screw a 6mm rod into that,about 4" along the rod add another clevis pin and to that put on the cable nipple, what do you think? or am i going a bit too far with it .
Old 5th April 2012, 08:09 AM
Here's what I used:
http://www.kitspares.co.uk/shop/item...=5016&catsub=0
Adrian
My Build Pictures:
Old 5th April 2012, 09:44 AM
I made a little bracket a bit like andy describes.
I need a better return spring though.
