Old 14th June 2012, 09:02 PM
BenBrooks BenBrooks is offline
Default Aluminium vs Steel floor
Hi all,
in the book it says to use the sierra roof (i.e. steel) as the floor and weld it on to the chassis but i've seen lots of you have used an aluminium sheet and secured it down with rivets. probably a silly question but are the rivets not a potential weak spot for rusting/chassis integrity and is attaching aluminium to steel in this way okay to do?
Ben
Old 14th June 2012, 09:45 PM
No because you also apply generous amounts of PU sealer to glue it on as well.
There is not a problem with ally to steel with this method.
Old 14th June 2012, 09:48 PM
Yes, using aluminium is more than fine. Remember its also bonded when riveting the aluminium to the chassis.
Old 14th June 2012, 09:49 PM
yeah there is a possibility that it could oxidize, i am going to fit a thin strip of rubber between them
Old 14th June 2012, 11:10 PM
Use pu the rubber will squash and split.
Old 14th June 2012, 11:24 PM
oh ok , what is pu?
Michael
Old 14th June 2012, 11:39 PM
Polyurathane
Old 14th June 2012, 11:42 PM
Good you say that actually! I've got geffin tons!! or access to it anyway!
Old 14th June 2012, 11:49 PM
cheers guys. could sikaflex be used instead of pu? purely because i've already got it sitting in the garage?
Old 14th June 2012, 11:56 PM
Yes, that should be fine to use, lots of builders use that stuff....careful what you let it get into contact with cos its super sticky
Welcome to the forum too Ben , photos of your build is a must
