Old 19th June 2012, 12:23 PM
Ricky Ricky is offline
Red face shock length
Hi everyone I have a question the haynes book says all 4 shocks are 13 inch open and 9 inch closed and when I looked at some of the photos some of the people on this forum have post of there shocks there are two the same and other two shorter shocks WHY ? If anyone can help please
Old 19th June 2012, 02:38 PM
Haven't noticed this myself,must be an illusion.All 4 shocks are definately the same although it is 13" with a 1" extension making them 14" from eye to eye.
Old 19th June 2012, 04:14 PM
I just don't have a picture or I would show you what I mean but I seen few pics with two of the shocks shorter then the other I'm not sure if its maybe adjustment that makes it look smaller I'm not sure
Old 19th June 2012, 04:34 PM
PorkChop PorkChop is offline
Whose build threads were you looking at? The SSC/NTS MX5 changes spec a 12" open rear damper and 13" open on the front.
Old 19th June 2012, 04:40 PM
That's a good point hey I really don't remember which one I saw but maybe I confused myself with that and saw the mx5 ones thanks guys for your help
Old 20th June 2012, 09:11 AM
ford sierra based car (book) needs 13"-9" with 1" extension or 14"-9.5" unextended.
the original book (version1) had 13"-9" but there was topping out on the damper in potholes with ride hight set correctly iirc
Old 20th June 2012, 12:16 PM
I'm building the sierra type so what shocks you think would be better
Old 20th June 2012, 12:22 PM
is the 1 inch extension is the eye on the top that the bolt goes through ?
Old 20th June 2012, 02:29 PM
Ricky,
If you haven't read it yet, there should be some answers in the very good Alga's FAQ section.
There is a chapter "What is the recommended suspension setup?"
http://www.haynes.co.uk/forums/showthread.php?t=8123
Sylvain
Old 20th June 2012, 06:16 PM
thanks for that but my main concern was the shock lengths if all four are the same cause im saw some pics of shocks and two looked shorter but pork chop said that i could of seen the mx5 ones so that confused me a bit cause the book says all for 13 inch open 9 inch closed just the spring rates diff
