Hi guys,
As i've lost all my saved photo's from when i was dismantling my doner, i can't remember what the bit below is for. P7070101.JPG P7070102.JPG P7070103.JPG Thanks Terry
If you need a friend, call me, if u need company call me, if you need help call me, if u need money this number is no longer available. |
My donor was a 1.8cvh sierra and from memory I have a similar relay, fairly sure it is one of the main relays? Sure tt or someone will be along shortly to confirm.
Russ |
Looks like the engine management master power relay.
From memory the only relay with a fuse attached to it like that is the radiator fan
I had one like that except it was green (with its own fuse). It was part of the ECU from memory so I removed it because of using a megajolt.
I can't remember what donor car you had Terry
That relay has the same part number as the Sierra I am currently working on. It's DOHC fitted with the exact same unit & it is the fuel pump relay. The colour codes of the wiring don't match mine though. I guess if you do not have an EFI engine it won't be the fuel pump relay. ![]()
The donor was originally a 1.8cvh, but was changed to a 2l pinto.
If it's for the ecu or a pump relay, i won't be needing it as i don't have either of these now. Thanks for your help guys. Hoping to have the car runing by next weekend, just got to sort out a new fuel pump and fuel regulator. Terry
