			 I am about to order the front brake pedal clevis but dont have my book with me.I would appreciate it if someone could tell me what the diameter is of the the rod that pushes inside the ford sierra master cylinder.From memory i think its either 6mm or 8mm?
			 Bigger is better,or is that only America,use eight and make rod from long bolt.
	Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice.  |
			 I used M8 threaded rod, worked fine.
	Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate.  |
			 Cheers guys,parts ordered.
