Old 4th September 2012, 01:19 PM
rapidtornado's Avatar
Default Pedal Box design...?!?
I have fabbed the std pedal box design out of the box but it looks a bit naff (due to my skills not necessarily the design)
I modelled the original design in CAD and then kept the hole centres but replaced the 'PBx' plates with tube instead.... any reason why this wouldn't work?
Rapid
Old 4th September 2012, 01:50 PM
Very funny, I did the exact opposite : I used tubes for pedal shafts and plates for brackets
http://www.haynes.co.uk/forums/showt...ighlight=Pedal
Cheers!
Old 4th September 2012, 07:51 PM
Is there room to get the pedal pivot bolts in and out. It's a bit tight on my pedal box.
Old 5th September 2012, 10:50 AM
Good point, skov.
Old 5th September 2012, 12:46 PM
If the bolts for clutch and acc go in one direction and the brake the other then it works OK.... I think
Old 5th September 2012, 08:51 PM
I'd say, if the brake pedal gives enough clearance to insert clutch and gas bolts from the brake pedal side, you're fine. The side walls will be very close.
Old 8th September 2012, 10:27 AM
i had a good old look at the pedalbox and when i boiled it down it got to one of two options totaly redesign one myself or find somthing to replace the orignal from a doner or aftermarket.
the other problem is the master cyl is very low and idealy you need to keep all the pipework lower so fluid leaks out in a problem not lets air in its much safer that way.
the problem i found is that almost all the aftermarket stuff is ballance bar brake cyl types that are a little tricker to set and lock for iva.
the result for me was to end up with a very nice drop down set with everything above your feet its the bit i like the most about my build.
