Old 10th June 2013, 06:37 PM
rpjg1975 rpjg1975 is offline
Default no power to starter?
Hey guys,
Just been out to turn over the engine in the roadster (1.8 cvh) and when I turn key to start......nothing. I dont seem to be getting power to the small starter motor wire.
Have run wire from start position on ignition key and small starter wire and it turns over perfectly. All I seem to have been able to work out is the the black/blue striped wire goes into the back of a small red relay (xii from memory) then back out. I have power going in on blue/black and also yellow/black but not out, if I pop the cover off the relay and manually click it together it turns over. If I put the red relay in the holder for they yellow one (fan switch I think) it clicks so presumably the relay is ok???
Just looking for some pointers as to where to start or if there is something stupid that I am missing?
Cheers in advance
Russ
