Old 18th May 2013, 04:59 AM
Fopro Fopro is offline
Default Lights always on
I need help to find out why my light are permantly on. I have used a 89 sierra column switch assembly and made my own loom. Other than the headlight issue every thin else works OK.
The sierra switch turns the side light on and off, but the headlights come on without using the switch. I have got the problem done to being in the dip circuit, but cant find out what it is. The dip relay is as as follows
86 to 56b on sierra stalk
85 to swithed live
30 to permanent live
87 to fuse.
Circuit looks similar to David Murray's
