Old 1st February 2014, 04:50 PM
Default Rear up rights
Been checking my rear up-rights and when I place the shock end in between there approx. 8mm difference, firstly is this right and if so are people just using spacers to make up the difference.
Old 1st February 2014, 05:58 PM
If you mean the gap between the bush and bracket then yes,spacers,washers look kak
Old 1st February 2014, 08:38 PM
I was thinking the same, I was also thinking of welding the spacer to each side of the upright and blending it to try and make it look one piece.
Old 1st February 2014, 08:40 PM
solved mine with some ally spacers.
Old 2nd February 2014, 10:00 PM
I used a stack of washers... They're a bitch to sting back onto the bolt after adjusting the camber... Thanks for the hint, I'll try to get some spacers made.
