Old 17th August 2010, 03:02 PM
Default Progress Report
Hi all, thought it was time for a quick progress report.
Nearly 4 months to the day that my chassis was started, it is all finish painted, ready to be taken back to my garage.
Cannot thank forum member Gus, enough for the hard work he has put in making my chassis with me during our half hour lunch breaks. At least his shopping bills have been cheap. Didn't give him time to eat!!
Attached are a few pics of the chassis & cage all painted and assembled.
Sorry if they are a bit dark. They look better on the camera.
Old 17th August 2010, 03:11 PM
3GE Components's Avatar
Looking good Dave
Kind regards
John
Old 17th August 2010, 03:12 PM
davidimurray's Avatar
Wow - that is looking brilliant. Lovely job you and Gus have done there.
Gus - is your car on the road now?
Old 17th August 2010, 04:53 PM
Looking real good, nice roll cage to.
Well done to you both.....AndyH
Old 17th August 2010, 07:45 PM
MightyMouth MightyMouth is offline
Here, I have adjusted them for you.
Old 17th August 2010, 08:09 PM
Jimmyd Jimmyd is offline
Looking good.!!!
Old 17th August 2010, 09:36 PM
gus's Avatar
gus gus is offline
Hi
What he forgot to say was it had all the fittings and brackets done,so hopefully no welding on it when at home.
Davidimurray - hope to have my car finished next week . Dash needs fitting , gear and hand brake gater and lots of trim. Then send off paper work .
Gus
Old 17th August 2010, 09:41 PM
Dave's chassis is looking fantastic
Nice to see that you have managed to crack on with your build Gus
When will we see the grand unveiling
Old 17th August 2010, 11:42 PM
WoW looking nice
Dave / Gus..... May I ask ......are the roll cage back stays & front down tubes welded to the chassis at the bottom?
reason I ask is that I,ve recently done mine but bolted them in with 4 bolts similar to the upper roll bar mounting, just in case I ever need to remove the roll bar.
I take it you both only have time for a kit kat in your lunch breaks, chassis is looking really nice
Old 18th August 2010, 08:19 AM
Thanks for all the comments guys.
I'll be glad to get it home to spend a bit more time on it. Not that i'll get much with a 3 year old boy to play with.
He does like cars though. He was sat in Gus's at the weekend eating biscuits, and getting crumbs all over the place!!
Andy the rollcage in completely bolted into the chassis. The rear stays each have 2no. M8 bolts welded into the bottom of them, which bolt through plates welded to the chassis rear frame. The front tubes each have 3 fixings which go through a plate welded into the corner of the chassis. These bolt will eventually go through the ali floor and a spreader plate underneath.
Yesterday was the first time the rollcage had been back on the chassis since we welded it all up. Went on like a glove and all the bolts went in first time.
