Old 19th August 2015, 08:05 AM
Default LED rear lights
Right chaps I could do with a little help or advice. I'm no sparky so this might be easy for someone to answer. I went to fit my rear light's last night into my rear arches, and where they would be the wiring will be very close to the wheel (witch I don't like). So 2 option. 1 Modify my rear arches again to bring my current light out a bit to clear the wheel or slim LED lighting. So had a look around and found some nice rear LED light clusters. what is the story with needing to fit resisters to clusters? I have read that you need to fit a resistor to a single LED but I cant find anything on clusters so could someone help me out before I go buying some
https://www.flickr.com/photos/124541083@N02/
Old 19th August 2015, 09:11 AM
Hi
If you are fitting led indicators you need a resistor otherwise they flash too fast.
If you are using mx5 electrics then scov had a work around which I used by removing on of the resistors from the relay
The details are on his build thread and were very easy to follow
Old 20th August 2015, 08:01 PM
garyt garyt is offline
As I have a combination of bulbs and leds I used the RDX relay, sorted
Old 24th August 2015, 03:15 PM
james3004's Avatar
I modified my standard Sierra flasher relay with a 100k potentiometer from maplin for about 70p.
Then turned it until I had flash rate that I was happy with
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 26th August 2015, 02:15 PM
Coozer's Avatar
Coozer Coozer is offline
You only need to increase the load for the indicators. As said a resister inline or simply replace the flasher unit with an LED one!
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 27th August 2015, 07:52 AM
Thanks for the info guys. But I have put a lot of thought into this and have decided to go with keeping the light's I have to match the others and to modify my rear arches as I have already got the gear around the garages, its just my time. Have a look at my pics and let me know you thought before I go cutting big holes in my arches.
Old 27th August 2015, 07:54 AM
Oh one more question is there a minimum or maximum gap between the brake light and indicator
Old 28th August 2015, 08:05 AM
Westfield site has piccy for lights and spacing
Old 28th August 2015, 02:13 PM
TSM Locost's Avatar
There you go.........http://westfield-world.com/svalights_rear.html
Be Lucky, Mike.
Old 29th August 2015, 08:13 AM
Thanks gents I have got that info which is really helpful anyway I was more interested in is there a gap setting between the indicator and brake light.
Also I have now started to do my mods to my arches and in not sure if I like it now might just carry on with it for now and make some nice custom arches after IVA
