Old 17th April 2017, 10:27 AM
Dave F's Avatar
Dave F Dave F is offline
Default Throttle cable MX5
I assume many if you have solved the same issue so though I'd put it to you all. I need a longer cable for my TMXR build, looking at and measuring the old one I need a 2mm inner cable with a barrel nipple 6mm Dia 10mm wide, is this combination like rocking horse s**t or is it just me. My ideas so far are get a thinner cable, a larger barrel and file it smaller or solder my own, what did you guys use? The other end I'll probably use an 90 degrees version of this: https://www.ebay.co.uk/itm/302191897699 and an eyelet like this: https://www.ebay.co.uk/itm/201464361954 pedal end, am I miles off the mark and am I over thinking it?
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 17th April 2017, 11:09 AM
garyout garyout is offline
Not done mine yet but was just going to get a universal cable kit from Venhills used them loads when I was into me motorbikes
Gary
Old 17th April 2017, 12:19 PM
garyt garyt is offline
Hi I used a universal one of eBay came with different nipples so was spot on for me
Old 17th April 2017, 04:23 PM
Dave F's Avatar
Thanks for that, think I'll just get one of these: https://www.ebay.co.uk/itm/171198151941.
God loves a trier
Old 17th April 2017, 04:43 PM
chris_smith chris_smith is offline
I used the original it fits just about once I moved the support bracket down an inch or so
Old 17th April 2017, 08:33 PM
Dave F's Avatar
That's a good point, I remember the bracket needs to be dropped to clear my bonnet, my have to play with the position as it is so dam close for the original.
God loves a trier
