			 Hi,
			I just cleaned some parts from the donor by electrolyse, it is very efficient, almost “magic”. I removed the seals and bearing from the rear wheel hub carrier. RH and LH parts are exactly the same. IMG_2536_1.JPG But one of them has an odd seal. It is mostly done of a metal ring, instead of being all rubber with metal ring inside as the other ones. IMG_2537_1.JPG Can anyone tell me if this is normal, or what is the reason why one of the 4 seals is different from the 3 others? Thank you by advance for your help.
	Sylvain Pictures of my completed Roadster https://www.flickr.com/photos/994983...7646799525542/ Build blog: http://vouchtroadster.blogspot.se/ https://caferacer-kawa-gpz-zx550.blogspot.com/  |
