Old 26th August 2009, 03:09 PM
axle's Avatar
axle axle is offline
Default Chassis paint
Hi
Can any body tell me what kind of paint would be durable and good value for money to paint the chassis. I have heard of 1-2-1 rust paint but it works out to be about £60 for 2 litres, lastly how much paint is needed?
Regards Axle
Old 26th August 2009, 04:09 PM
i coated the frame in red oxide, cheep from wilkos or farmers coops and then painted it with hamerite strait to metal, that stuffs expensive, but still only about£40 for a 1/2 gallon, the finish is quite good and the wishbones have been done for over a year now and theres no sign of any problems
Old 26th August 2009, 04:10 PM
and i didnt use the whole can yet doin the wishbones and chassis
Old 26th August 2009, 04:14 PM
i got 2L of epoxy mastic 121. i think from memory i used about 1-1.5l spraying it on with a micro spray gun. results are in this months complete kit car. good thing is that there is plenty left for touch ups if i ever make any alterations to the chassis.
im happy with the results but it did chip easily at first. now its been on the car over a month it seems to be more robust.
i calculated the cost of doing it with spray cans from halfords and it worked out around £90. powder coating was £140 but ideally you want it sand blasted before powder coat adding another £60 to the cost.
by far the most cost effective solution is hamerite but i would say its slightly less durable than the epoxy 121.
Old 26th August 2009, 08:05 PM
Adam R. Adam R. is offline
I use hammerite metalmaster
http://www.hammerite.com/uk/products...talmaster.html
carbon master
hayens roadster + carbon westfield body
English is not my native language.
If my grammar/spelling is off please correct me, I'm still learning!
Old 31st August 2009, 03:16 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
Chassis black is actually made for the job, it is very robust, cheap, easy to apply and easy to repair if needed.
Available from all good motor factors
