Old 19th September 2009, 12:15 AM
nudgebar nudgebar is offline
Default has anyone used a GSXR1000 motor
I am going to use a gsxr 1000 just wondering why the R1 motor
is used the most?
can anyone shed some light on this?
Old 19th September 2009, 12:48 AM
is used the most?
Used the most in what? Dunno how many Haynes roadsters have an R1 lump, I am sure the majority have used something easily available, like a Sierra engine, or a zetec.
People use all sorts of engines, Hedgabuser is a firm favourite, giving the thick end of 180+ bhp.
There is a whole list of engines used a lot in BECS - ZX (10, 12, 14R), Blackbird, ZZR 14, R1, GSXR thou, Fireblade etc.
The R1 has been around for a while and the engines come up at a reasonable price quite a lot.
Don't forget, when using a bike lump you will need a reverse box.
Welcome to the forum by the way, maybe a little info about yourself and your build in the announcements section would be helpful.
Sean
Old 19th September 2009, 08:16 AM
7ishNZ 7ishNZ is offline
R1 because it doesn't need to be dry-sumped... a simple baffle plate and a set of uprated clutch springs is all you have to add.
Old 23rd September 2009, 02:49 PM
chriseyj chriseyj is offline
I've been looking at the zzr1100 make decent power and seem to come up for a reasonable price. Does anyone know if these need to be dry sumped?
I have given up on the idea of a gpz1000rx someone offered me I think there are more powerful and lighter engines around.
I've also noticed a few older bikes have the timing chain running around the centre of the block/head like the Yamaha Fazer and CBR 1000 f, how do you change the chain? Is it a rebuild job?
Old 23rd September 2009, 04:05 PM
Probably best doing a search on Locost Builders. There are large numbers of BEC builders on there
Sean
