Old 25th October 2009, 11:31 PM
Default Drilled strip in tunnel
OK, so, my chassis is almost entirely welded (just need to fit a few brackets)
I plan on fitting the drilled srtip into the transmission tunnel to aid future fitting of brake/fuel/electrickery lines.
I will be using 25x3mm steel stip with 3.2mm holes at 50mm centres.
Where in the tunnel does it get welded?? I am assuming it gets welded on the top rails, inside the tunnel, pointing down??
Any pointers/photos most appreciated
Sean
