Old 25th November 2009, 03:05 PM
axle's Avatar
axle axle is offline
Default Rear Disc Brake Cable
Hi
Can anybody tell me if the car was fitted with the rear disc brake. Would the cable need to be shortend.
Regards Axle
Old 25th November 2009, 03:20 PM
gingea1pom's Avatar
Default Yes
Yes, in a word
The distance from your Roadster hand break to the rear callipers is shorter than the distance from the Sierra hand break to the rear callipers unless you are installing rear seats!
I stand to be corrected!
Cheers Ginge
Build Pictures
Old 25th November 2009, 03:45 PM
axle's Avatar
Hi
Thanks for your reply, how are the ends recrimped or resoldered again?
Regards Axle
Old 25th November 2009, 03:57 PM
gingea1pom's Avatar
Well I have not done it myself but AshG cable clamped the cable to shorten it. Others have cut the cable and re-soldered a nipple on.
If we wait a little someone will be along with a slightly more concise answer.
Cheers Ginge
Build Pictures
Old 25th November 2009, 07:27 PM
It may be possible to use cables from a Sharan or the Ford derivative the name escapes me at the mo,they are fairly short and have a long slotted end that will require a new handbrake end making.
I have just aquired some and will try to post a pic tomorrow.
Galaxy !
Old 25th November 2009, 07:41 PM
gingea1pom's Avatar
See every time this forum comes up trumps just a mind of information.
Build Pictures
Old 25th November 2009, 08:36 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi,apparently (on lcb) your local friendly aa man has a box of ends that fit like solderless nipples now i cant vouch for this but its worth a try.
let me know how you sort this as ill need to do the same.
otherwise i beleive someone like speedy cables can make them up to your spec
i have an rs2000 mk5 handbrake cable on my disc braked mk2 escort but i think thatll be too long too
Ray
Old 25th November 2009, 10:01 PM
Land Locked's Avatar
Galaxy !
Ford Galaxy? Oops, tooo damn slow
Regards (The mad Sarf Efriken)
Last edited by Land Locked : 25th November 2009 at 10:02 PM. Reason: to add last line
Old 25th November 2009, 10:42 PM
Nice try dude !
Old 26th November 2009, 01:24 AM
It may be possible to use cables from a Sharan or the Ford derivative the name escapes me at the mo [...]
Galaxy !
VW Sharan, Ford Galaxy, SEAT Alhambra. All built on the same line at a joint venture in Portugal... I've seen all three lined up side by side at a used car market -- the only difference was the grill design.
