Old 1st March 2010, 10:43 PM
Big Vern Big Vern is offline
Default Pinto to MT75 ?
Twin turbo might know the answer to this one
Now I know Ford fitted the injection Pinto on to the MT75 for the transit van but Ford never did this on the Sierra/Granada.
But has anyone done this? and if so what was involved?
Or does anyone have a DOHC knocking about with std clutch and flywheel who cold do some measuring for me?
Regards BV.
Old 2nd March 2010, 08:22 AM
Never tried it myself, But I think it's a case of using the 1.8 CVH fly and clutch.
Old 2nd March 2010, 11:55 AM
Dratt, I was sooo hoping you'd know the answer
I've used the CVH flywheel to put a DOHC onto a Type 9 which was very successful , at least until the type 9 'erupted'.
Zetecs need some sort of spacer on the release brg when fitting to an MT75 which used to be available from Westfield (no longer - they will only supply genuine westie owners) so I'm guessing it'd be the same for the Pinto.
You don't happen to have a dohc with stock flywheel sitting around do you?
Regards BV.
Old 2nd March 2010, 12:02 PM
I can also confirm a 1.8cvh flywheel goes onto a DOHC. The 1.8cvh flywheel also seems to accept a pinto clutch and pressure plate. Dunno about clutch release bearing though. I used a CT133 on mine, but I'm using a clutch / flywheel combo off an MTX75 gearbox.
Old 2nd March 2010, 02:00 PM
Hi Deezee,
How will you make the FWD clutch work with the RWD gearbox. The MtX75 gearbox uses 'lolift' clutches so yu'll have a very stiff clutchpedal
I would also have thought the release arm will run out of travel - hence the need for the westie guys to use a special release brg.
However if this combo works it might help me solve another problem.
Anyone got and old MTX75 gearbox sitting around?
BV
Old 2nd March 2010, 02:52 PM
Big Vern
Try burton power they do a lot of clutch release bearings and spacers for ford combos.
www.burtonpower.co.uk
Old 2nd March 2010, 03:22 PM
Originally Posted by Big Vern View Post
Hi Deezee,
How will you make the FWD clutch work with the RWD gearbox. The MtX75 gearbox uses 'lolift' clutches so yu'll have a very stiff clutchpedal.
BV
How? Very Easily Yeah the clutch has a very obvious bite on it. Almost on / off. But it saved hundreds on an after market flywheel / clutch / clutch cover. My build is on quite a tight budget, so I'm re-using loads of parts. When I have the cash in the future, I'll change things over to some better parts.
I used a capri release bearing. Real thick job. Another guy I talked too on Locost builders butchered his clutch fork to move the standard bearing forward (Picture below)
Old 2nd March 2010, 03:50 PM
You can also remake the pivot point to move the arm forward a bit.
Old 2nd March 2010, 06:48 PM
DOH!
Now you point it out I've seen something similar done before.
At least I know I can use an MT75 as a last resort now
Could still do with finding someone with a cable clutch MTX75 though to sort out another problem
BV
