Old 16th March 2010, 09:28 AM
Simon_K Simon_K is offline
Default Sierra Donors in Brandon, Suffolk
Wiz along to e-prey and check these two out.
Pity they appear to have the less favoured 1.8 CVH engine.
http://cgi.ebay.co.uk/Ford-sierra-sp...item19baaf4dd8
http://cgi.ebay.co.uk/Ford-sierra-sp...item19baaf576b
Gearbox identification has been requested, as both are manual.
If you simply MUST have a 2.0 ltr Zetec, well they have that covered too.
http://cgi.ebay.co.uk/Ford-Mondeo-Es...item19baaf647f
Old 16th March 2010, 11:47 AM
CVH always has a TYPE9
Old 16th March 2010, 10:26 PM
Exclamation A word of caution
These 2 cars may prove to be a bargain basement source of donor parts
Just a couple of points to bear in mind.
Both have no V5 documents ( & You won't be able to get one ) , being ex US military there is not likely to be any record of them on DVLA's data base
This being the case .... There may be problems when it comes to registering your build with your local DVLA & almost certainly end up with a Q plate
Just food for thought .... If you don't mind a Q plate & a little hassle, go for it .... There may be a bargain to be had
Old 17th March 2010, 09:23 AM
Exclamation Age related plate
I wonder if possible to get an age related plate if you can prove age of engine from Ford Heritage?
I doubt there would be any problem proving the date of manufacture for the engine
Problems will most likely arise when you try to prove the age & source of your other donor parts !!
In order to qualify for an age related plate, most of the donors parts count towards DVLA's points system for an age related plate.
With no V5 it is likely to prove difficult .... That's not to say it's impossible though
Old 17th March 2010, 09:03 PM
CVH 1.8 is OK. You won't be tuning it anyway, but you'll be able to use at least the shortened steel sump and starter for your Zetec swap ;-)
