Old 21st March 2010, 03:56 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Default Brake pipe.
Just after you thoughts really,
already ran the front brake pipes as per book (to the brackets welded to chassis) before finding out that you cannot have a flexible hose running through the ali side.
I have now moved the mounting points to the ali sides (with reinforcement ring), but now one of the pipes is not long enough.
Do I replace the whole brake line or should I just put an inline joiner in and add the extra I need.
I think I know which way I might go, just wanted ideas.
Daz...
Old 21st March 2010, 04:09 PM
Personaly Daz
I would make a new pipe .... Although I doubt a joiner would fail the IVA, the tester may find it less than ideal & might look closer to see if short cuts have been made elsewhere
Old 21st March 2010, 05:42 PM
DaddyA's Avatar
Cheers Ronnie,
I was leaning that way anyway, plus I can try again to get it above the chassis rail (near MC.
Anyone got spare brake line??? (Joking)
Daz...
