Old 4th April 2010, 10:34 PM
geeman's Avatar
geeman geeman is offline
Default A build update... with a few Q's
Though id put in a build update as i don't seem to have really done so properly in a while. Ill put up some pics tomorrow as well.
I have now got a fully fitted engine, not fitted the exhaust system but Ive made most of it including a crude 4-2-1 manifold out of steel(doesn't look great). I have done the engine electrics properly now.
one thing i am unsure about is clutch and throttle cables, i seem to have lost both of them, so will end up buying them anyway. What should i be getting for the roadster, as the sierra ones are too long?
I have also now got a fuel tank fitted(almost), and have done flexi fuel lines at the rear section as i wasnt able to bend the 8mm copper tubing properly at the rear.
In terms of electric i haven't started on a lighting loom yet, but i should get onto that in a week or so.
On Friday i jacked up the rear and gave the wheels a good spin to check my prop wasn't causing much vibration at the moment, but the entire engine started shaking. What seems to be the problem isn't the prop, the box and diff aren't entirety in line, so im going to slot the diff mount holes so i can adjust the diffs position, as it isn't too far off being in line with the gearbox.
My brakes are done, except i need to buy some braided hoses to go to the wheels, should i just get these from local motor factor?
I have also started to get the bodywork on, and have cut suitable holes in the side panels, and have mock fitted the nosecone. One thing i wasn't sure about is how often i should secure the side panels with riv-nuts or rivets?
I should add i'm glad i picked orange, looks great!!!!
last thing i'm unsure about is the coolant system, how is all the plumbing done on the 1.8 cvh, as there seem to be numerous connector on the engine block and i'm not sure how to do it all.?
Thanks!
edit: i remembered i took a few pics last weeks, ill add some more tomorrow:
I should also say, held the rear tub in position on the car, and can safely say it wont fit in my garage with the rear tub on as without it on it is already touching the garage door at the back, so ill be leaving that till as close to the end as possible.
my build pics
