Old 18th May 2010, 05:52 AM
Divo Divo is offline
Default Haynes Pedal box with Clutch Master cylinder
Hi all,
Has anyone constructed the pedal box with a hydraulic clutch (MX5)? If so where any alterations required to the pedal position for the clutch to ensure enough travel to fully engage the clutch?
Mark
Old 18th May 2010, 11:52 AM
I would imagine it depends on where the piston rod is in relation to the pivot point. Can't see it being a big issue, you probably want to replicate the design of the brake pedal.
Old 19th May 2010, 01:55 AM
If you have the donor one is it not possible to measure the rod movement & position in relation to pedal pivot and alter the haynes one to replicate this.
