Old 4th May 2010, 11:28 AM
Jeze2903's Avatar
Jeze2903 Jeze2903 is offline
Default Front Grille
H, does anyone know if the mesh grille fitted behind the nosecone needs to comply to any SVA regs? Will expanded metal mesh be okay, hole size aprox 8mm?
Also is no-nails type adhesive good enough to fit it to the nose cone?
Old 4th May 2010, 08:00 PM
Jeze2903's Avatar
Grille looks good Adrian. That's pretty much what I had in mind, will check out IVA manual
Thanks for help
