Old 17th August 2010, 11:10 AM
Peter-C Peter-C is offline
Default Struggling !!
I cant get my head around brake pipes. I thought that if the fitting on the pipe is say male then it has one type of end and if female the other type. But looking at the fitting to a flexible pipe this doesn't appear to be the case. Can anyone clear this up please ? Hopefully there will be attachments.
Old 17th August 2010, 11:38 AM
Looking at the flexi pipe pictured, you'll need a male end on the copper pipe
As a general rule of thumb if one fitting is concave ( Female ), The other fitting will need to be convex ( Male ) in order to marry the two fittings together
Old 17th August 2010, 02:21 PM
nope that flexi is male its just chamfered your female flare on the second pic is poor thats the problem. you need to turn the tool into it a lot more.
My Pictures
Old 17th August 2010, 08:31 PM
Hi Peter
May I ask if that is a new flexi pipe & do you have a better picture ?
Your image is quite difficult to view in any great detail.
Here's a typical female pipe flare
I find it best to avoid over cooking the forming of the female flare, tends to make them a little weak & troublesome to seal.
I know these are not flexi pipe ends but they do represent the kind of ends usualy found on flexi pipes
Female left & male right
It has been my personal experience that the male end is by far the most common end to find at the rigid pipe end.
Old 17th August 2010, 08:54 PM
Hi Ronnie,
I've taken another photo but I can't copy and paste it so it has to be an attachment again. Both ends of the flexi pipe are the same.
Peter
Old 17th August 2010, 09:05 PM
Hi Peter
That certainly looks as if that was made to take a female flare as Ash has said
Don't think I have seen one quite so chamfered as that before.
Perhaps Flyerncle will give us his thoughts
As for me .... Gotta get to specsavers
Old 17th August 2010, 09:07 PM
To be fair Ronnie, when I looked at my first set of attachments, I couldn't work out what they were either !!! Still don't know how to copy and paste pictures.
Old 17th August 2010, 09:16 PM
I upload my pictures to photobucket & copy then paste the IMG code into the forum post
Probably can be done for images stored on your PC but I do not have a clue how to
Old 18th August 2010, 09:29 AM
Hi Adrian,
Its coming along, but a bit slower than I would like. With holidays,etc. it's taken almost a month to complete the brake and fuel lines. Hopefully in the next fortnight, still off school, I can make inroads.
Peter
Old 18th August 2010, 09:02 PM
Ronnie,it would appear to be a male fitting as previously said. I think as the picture is very close and detailed it looks a little odd but copper brake pipe would mould to fit as it's soft.
