Old 21st September 2010, 07:50 PM
dan_g8 dan_g8 is offline
Default anyone know somewhere to get my hubs refurbished around essex?
as per title, i need to find somewhere to refurbish my front hubs (new bearings & paint touch up) as i havent got a torque wrench that goes high enough nor do i have a work bench & vice which will handle the hub nut torque.
My local garage quoted me over £70 to do the job. there must be a cheaper place out there?
Old 21st September 2010, 09:36 PM
If that includes parts and labour its not bad,why not ask them to loosen the nuts for you and fit the bits and get them to tighten them back up, it takes seconds with an impact gun and I did mine the other day in ten minutes.
Old 21st September 2010, 09:44 PM
snapper snapper is offline
Find an engineering firm, they will get the hub nuts off, replacing bearings on a Sierra is easy then take back to the engineering firm to torque them up.
Where are you in the world?
You might have some club help close by
Old 21st September 2010, 09:46 PM
Essex !
Old 21st September 2010, 10:19 PM
Dan, you know where I am if you need a large vice and some brute force, bring the new bearings and some biscuits.
Old 23rd September 2010, 12:31 PM
Thanks phill, you have email.
