Old 27th September 2010, 03:30 PM
mikemph mikemph is offline
Default Plate thicknesses for brackets and mounts etc
I have had a read through the book but could not see anywhere that is said the thinkness for all the brackets etc shown in the back pages.
I have access to a plasma cutter which saves hours of cutting a filing. I have made up the suspension mountings and diff mounts. If some could list what thickness for each component that would be great.
Old 27th September 2010, 04:24 PM
Hi Mike
Have a closer look at the book
The material thickness is noted below the part number.
For example, page 178
RU1
3 plate
Or page 179
RU7
10 plate
A little confusing as the mm has been omited
That said, the suspension & shock brackets, do not have a material thickness on the drawing & they are 3mm ( Tis mentioned in the text though )
I hope that helps a little
Old 27th September 2010, 07:43 PM
My bad!!
Cheers for clearing that up for me.... I must book a eye test
